Multiecuscan (MES) - Popular Settings Compilation
Multiecuscan (MES) Configuration for the Alfa Romeo Giulia/Stelvio NON Quadrifoglio
Prerequisites
Editing Raw PROXI Data
  • Navigate to:
    • Alfa Romeo Giulia 2.0 Turbo 16V Multiair → Body → CAN Setup / PROXI ALIGNMENT PROCEDURE (952)
    • Click on the Adjustment tab
  • Hit Ctrl+Alt+C to open the PROXI bytes dialog.
NOTE: It is highly recommended that you select all and save this PROXI data to a text file for ease of restore if you happen to mess something up.
WARNING Pay close attention and only alter what you are attempting to alter as these settings can have dire consequences if changed unknowingly.
PROXI Alignment Procedures
  1. Select PROXI ALIGNMENT PROCEDURE and hit Execute
  2. Follow the prompts, switch cables when prompted
  3. Once the PROXI alignment procedure is complete you will need to run a few calibrations to remove the numerous warning lights you more than likely have
  4. Disconnect from the Body module
  5. Connect to the ABS / Continental ABS MK C1 module. (Requires gray cable)
  6. Select Parameters tab, check Steering Angle parameter and set wheel so it’s at 0°
  7. Select the Adjustments tab and perform the following three procedures:
    • Reset steering angle
    • Lateral and longitudinal acceleration sensor calibration
    • Pressure sensor calibration
  8. Once these are complete, disconnect from the ABS module
  9. Unplug the OBD2 adapter.
  10. Turn off the vehicle and wait >30 seconds until the dash lights all turn off.
  11. Turn on the vehicle (no start) and turn the steering wheel full lock, left and right and back to center.
  12. Turn off the vehicle again, wait >30 seconds
  13. Turn on and all warning lights should be gone
    • If errors do not clear, repeat steps 10-12
Configurations
Popular MultiEcuScan (MES) PROXI Settings.docx
Enable Race Mode:
  • Body → CAN Setup
  • Choose:
    • If older than MES version 4.5:
      • To enter PROXI configuration, go to the Adjustment tab, then hit Ctrl+Alt+C (Custom PROXI)
      • Find byte 88. It should be “AC” (OEM value)
      • Replace AC with CC or EC in byte 88
      • Hit the Execute or OK button (I don’t remember what it is)
    • If MES 4.5 or higher:
      • Click the Adjustments tab, select Dynamic Control Selector, click Execute in the lower right
      • Choose either of the other two modes besides Type 1 (OEM setting AC)
      • Type 3/DNA/Sport is EC, and Type 2/DNA is CC
      • Choose one and click OK
  • PROXI alignment is needed
Enable Adaptive Cruise (ACC+)
  • Body → CAN Setup
  • set “Cruise Control” to “disabled”
  • set “ACC” to “ACC+”
  • PROXI alignment needed
Enable EU Paddle Shifter Logic
  • Body → CAN Setup
  • Byte 156, bits 4-5 (need to do bitwise calculation):
    • EU version (shift from P/R to D with [+] paddle, [-] together with [+] shifts to N):
      • xx00xxxx
    • US version:
      • xx01xxxx
Enable Window Comfort Opening/Closing (doesn’t work for all markets)
  • For MES version >= 4.7:
    • Body → CAN Setup → Adjustments
    • Windows comfort something something: enable
  • For MES version < 4.7 you need to configure the PROXI byte:
    • Byte 58, bit 1:
      • disabled
        • xxxxxx0x
      • enabled:
        • xxxxxx1x
Enable After-wipe (extra wipe after normal sprayer sequence)
  • Body → CAN Setup
  • byte 126, bit 5:
    • after-wipe enabled:
      • xx0xxxxx
    • after-wipe disabled:
      • xx1xxxxx
Adjust TPMS Pressure Thresholds
  • Body → RFHub → Adjustments (MES >= 4.7R3)
  • Front / Rear wheels pressure reference (do both)
  • I chose 32 / 34 F/R 32F/34R
  • NO PROXI alignment necessary
Disable Seat Belt Chime
  • Dashboard → Instrument Panel
  • Adjustments tab, Find it there somewhere
Battery type
NOTES
Leaving this information here for historical purposes.
* Body → CAN Setup
* **Battery type
byte 63, bits 0-3 (bit order: 76543210):**:
* xxxx0001 - 80Ah 680A - default setting for Giulia/Stelvio EU
* xxxx0010 - 95Ah 800A - default setting for Giulia/Stelvio US
* xxxx0011 - 80Ah 680A - default setting for diesel Giulia/Stelvio
* xxxx1000 - H7 flooded
* xxxx1001 - H7 AGM;
* xxxx1010 - H8 flooded;
* xxxx1011 - H8 AGM - default setting for Giulia/Stelvio MY20 models US/EU
References
May be you could add what I mentioned here:
I have an agm ‘95Ah 850a’ whats the two digit value of ‘xxxx0010’ please?
Hi @TU5h13 ,
It depends on the other values in that two digit hex value.
What is your current hex value for byte 63?
81 is my current value
Sorry for the delay, been busy.
Hexadecimal 81 = Binary 1000 0001
You need to change the 4 bits for the xxxx1010 - H8 flooded setting:
BIN 1000 1010 = HEX 8A
8A
I found a tutorial for enabling SBL (Static Bending Lights) on Giulia since every base Giulia with xenons have them.
Followed it and tried to change in Body using MES both:
  • byte #149 => 0x04
  • value “Cornering Lights” to “Present”
    I got the option in menu but it just doesn’t work. I tried to run AlfaOBD and when I try to test it I receive strange message:
Not all base vehicles, especially the later revisions and Nero packages (for some reason), can support that… from what I remember.
Even if it does have proper bulbs?
Mine is “Super” trim, EU model from France.
The Nero Edizione edition also has those LEDs, but they are basically dead… and we don’t know why that is.
@SniZ may have an idea.
How to code with Multiecuscan a replaced ACC from different car?
The actual radar sensor in the bumper? No clue.
Hi guys… is there any table with all the bytes and values that can be changed?
Hi Giorgos,
I do have a Google doc with a lot of the settings that I use in there. Not all of them work, fyi, but here it is…
I’m sure there are more out there; I should spend some time gathering them up.
Hi FizzGiGG, thanks for the reply and the file!
I will try myself to find some more and I will let you know if I manage something!
Hi @FizzGiGG
It’s great to read your Poxi alignment setting, especially the binary code on battery type. Now I’m sure this is the reason that my battery never has a chance to fully charged by the smart alternator.
My US version 2019 Giulia Q4 was bought used 3 years ago and it has a Mopar AGM battery with CCA 800. This AGM battery probably not from the factory and I believe the charging logic was incorrect in all these years
‘82’ is my current Hex value for byte 63 = Binary 10000010. I understand the xxxx0010 = 95Ah 800A but I dont understand the battery type in this set of binary.
If I want to register H8 AGM 95Ah 800A battery to the ECU, what is the correct Hex value?
What is the correct Hex value for a ‘H8 (EFB) 95Ah 800A battery to the ECU?
NO proxi alignment necessary after changes on battery type?
Thanks
Hey @Danowen ,
I don’t get a ton of traffic over here, so I don’t always check on new posts. Sorry about the delay.
xxxx1011 is for AGM. So you’ll update your value from 10000010 to 10001011 (8B).
I believe you need to do a proxi alignment, but of course I could be wrong.
GL!
Hi, i have 2019 Giulia TI imported from USA and I need to know what bite is responsible for rear break lights, so I can separate them from rear blinkers. I have tried to change it normally in mes but it is always stuck on “in progress”.
Any help will be appreciated
Welcome to the site. I don’t know the answer to that but I can see what I can find for you. You may need to change the country code, but I know that has caused issues with certain modules as they aren’t compatible with the EU country code.
Let’s start at the basics…
What are you using for hardware? (e.g. windows laptop, android, obd dongle, etc.)
Do you have an SGW bypass?
Check out my articles for MES in the Library.
